Choice filter with Dynamic Lists
218
02-23-2024 05:51 AM
GeorgeF
New Contributor III
we are using the dynamic list capability to store about 8 different tables.
Some of these tables need to be related (i..e choice will filter results of next table).
We used to do this with a separate CSV and a choice filter, but because of thousands of records and frequency of updates we moved to dynamic lists.
Is it possible to filter the results of a dynamic list, based on the selection of a previous dynamic list?
Thank you,
abureaux
MVP Regular Contributor
Cascading selects
EDIT: WHERE clauses and search options are also helpful to look into.
GeorgeF
New Contributor III
Thank you.
Do cascade select work with tables stored in AGOL referenced through the "search" expression?
GeorgeF
New Contributor III
I was wondering if there is an update on this as I havent been able to make cascade selects work with Tables hosted directly in AGOL.
Thank you
