Choice Filter dos not work in Web View when more than one condition is coded
569
03-27-2025 12:23 AM
NaeimBabaii
I have a dropdown menu (select one from file.csv) with a Choice Filter that has two dependencies:
  1. Reading a value entered from a previous dropdown.
  2. Filtering it based on a field in an external CSV file.
Problem: The Field Map App version works correctly and shows the filtered result in the dropdown menu. However, the web version does not return any result at all.
i believe there is a compatibility issue with the web version of Survey 123 to compile those condition in the choice filter.
typenamelabelhintguidance_hintappearancerequiredrequired_messagereadonlydefaultcalculationconstraintconstraint_messagerelevantchoice_filter
select_one_from_file BIRDS_FieldObserverOrgs.csvconsultantConsultant  autocomplete        isFieldObserver="TRUE"
select_one_from_file BIRDS_ContractorPersons.csvapproverApprover:  autocomplete        company=${consultant} and isApprover="TRUE"
