Change html label of read-only text question input?
838
05-13-2024 09:31 AM
emoreno
Hello ESRI Community!
I have kind of a niche question. I have a survey that uses pulldata to display specific promotions available to our customers, by pulling from a reference layer and inputting that value into a promo field in our survey. I received feedback today that the promotion that gets displayed is very small compared to the text of the question itself. Is there a way to change the way the text gets displayed in that read-only text question? I've seen it's possible for list choices and for the question itself, but nothing about the value that gets input in the read-only text question. Any help is appreciated!
abureaux
MVP Frequent Contributor
I think I understand. And if that lower text is the "read only" part of a text field, then "no" you can't change that.
However, you can forego the text field all together and use a note. Then format the text with HTML formatting as normal.
