Change geopoint location
923
08-13-2018 06:35 AM
by Anonymous User
Not applicable
I miss the feature that the user could press a button in the upper right corner of the map in order to get a new location. It was a round-circle
Many of my users use a survey with geopoints in repeats. When they have done one repeat- they press the plus-sign and make a new repeat. The problem is that the next repeat have the coordinates from when the plus-sign was pressed and not from the next sample plot.
It is natural to press the plus-sign because it is perceived as a saving-button.
Is it possible to get back the round-circle-button?
I also miss the ability to open the map and choose where the plot should be situated.
The problems have occured during the last months. Bull release?
We use the iOS-app 3.0.134
JamesTedrick
Esri Esteemed Contributor
Hi Johan,
The "locate me" button is still present - is it not appearing in your forms?
I'm not sure what difference in repeat layout you are seeing - I tested with an earlier version (2.5) and teh UI looks the same to me.
