Centre geotrace/geopoint map base on point location from Collector
768
02-16-2021 01:17 PM
ChrisRoberts2
Hi All
I was wondering if its possible to centre a geotrace or geopoint question map based on the coordinates of a point from Collector.
The use case is that we have a Collector Map showing the point location observations of pest plant and animals.  The field officer will select a point then have a hyperlink to open Survey123 to either capture a line or polygon treatment area.  The officer may not always be at the exact location of the point in question, so using the default GPS location isnt always an option. I have tried just passing the lats and longs of the point (using Arcade) to the geotrace question but it doesnt seem to work.
Cheers
Chris
ChrisRoberts2
Any thoughts on this anyone?
