Center Survey123 point using web layer coordinate fields
822
06-03-2022 09:48 AM
ErikHoltz
I am using a web layer popup to open a Survey123 mobile form, pre-populate certain questions in the form, and center a geopoint location for the form. The answers are pre-populating correctly and the center function is mostly working based on latitude and longitude fields in the web layer. But the points associated with the submitted Survey123 forms are about a half mile away from the web layer point that was used to open the survey form. The latitude and longitude values stored in the web layer fields are in decimal degrees and have 8 decimal places, so I'm guessing those values are somehow being rounded off when the Survey123 geopoint is created. Is there a way to ensure the Survey123 point centers directly on top of the original web layer point?
