cascading select not working in web app
1036
02-28-2022 03:30 PM
PaulPetersen1
I'm working on a Survey123 form that contains a simple cascading select. It works fine with Survey123 Connect and with the web app. However, it is not working in the web app (which is the end-location of this survey). When I click on the first dropdown, the contingent dropdown does not populate. As far as I can tell from my reading, cascading dropdowns/choice filters should be supported in the web app. Any ideas as to where I should start looking?
PaulPetersen1
I ended up getting this to work by using an external .csv instead of the choices tab
