Cant see the data
6924
21
04-11-2018 02:03 PM
JumaKhudonazarov
When I submit the data and go to survey123.arcgias.com to section of data I can see my data , but if export to cell all information there. `what is wrong?
JumaKhudonazarov
Do you have any staff in UK who is dealing with survey123?
JamesTedrick
Esri Esteemed Contributor
Thanks for the info.  Can you share the form design with me (you can e-mail jtedrick @ Esri.com).  Otherwise, yes, you can work through Esri UK - cconnollyesriuk-esridist‌, what would be the appropriate channel?
JumaKhudonazarov
Great will send you the form now , thanks for all support.
CarmelConnolly
Thanks James Tedrick‌, Juma, our tech support team in the UK will be able to help too, they can be contacted on 01296 745 555 or through [email protected]
Carmel
JumaKhudonazarov
ok thanks. Richard has been in touch  but  no solution so far. It looks like other people have  have similar concern.
JumaKhudonazarov
Hi Carmel,
Hope all ok. The problem we having is  more technical and needs to be looked  at high level. Can someone please help?
Best regards,
Juma
CharlesGantz
I also have this problem. Here is the screenshot:
Also, when I try to open in Map Viewer, all I get is an empty window, no map. Older surveys work properly. Also my survey has repeats, but I don't see them in the table.
JamesTedrick
Hi Charles,
Your screenshot did not come through - can you repost?
JumaKhudonazarov
Hi James,
Hope all ok. have you managed to look at my form ? I still have  the same problem.
Best regards,
Juma
JamesTedrick
Hi Juma,
Yes, I can see the issue you are experiencing.  I'll get an issue filed to examine what's going on.
