I have checked the iteminfo file and the item number is correct. I did create a joined view of the data two days ago, but deleted both of those layers. When I go into AGOL and open the feature service, attempt to add a field on the backend, the add field option is missing. I have attached the log file when I sync and it says schema changes not allowed. There are over a 1500 consequential records in this feature service, so need to come up with a solution that maintains the data.
Problem solved itself. After logging in today I was able to add a field and publish my Survey123 connect form. There seems to be a lag when changes are made to a feature service and for them to take effect. I have noticed this with 3 different operations this week. I am assuming it was after I deleted the dependent join layers from the recycle bin, and it just took a few minutes for changes to take effect and allow schema changes to the feature service again.
