Can you utilize if function in calculation with pulldata?
936
11-16-2022 11:40 AM
ArmstKP
I am trying to run a calculation if the string-length of a field is greater than zero...?
Is this possible?
DougBrowning
MVP Esteemed Contributor
I have seen this posted before I think.  Have the pulldata in one field then check it with the if referencing that temp field.  Can set bind esri to null to keep the temp field out of the service.
hope that helps
DougBrowning
hope that helps
ArmstKP
Thank you.  What I wound-up doing was using the relevant field to make the calculation only relevant when the other field has a string-length > 0.
Appreciate your help @DougBrowning
