Can't send and get data
1434
06-27-2018 07:58 AM
by Anonymous User
Not applicable
I can't send collected data and get existing survey data through Survey123 for ArcGIS desktop application.  It started from last night.  My colleague is currently visiting a place to teach how to use the survey application and now it isn't working.  After clicking Sent or Inbox button, I see "Getting service information" screen and it does nothing.  I would like to provide my colleague solution to this problem. To note that, the survey application is created based on the point feature layer.  I would very much appreciate your assistance.
JamesTedrick
Esri Esteemed Contributor
Hi Makiko,
Last night ArcGIS Online (What's New in ArcGIS Online (June 2018) ) - there might have been some service interruption because of that.  Can your user restart Survey123 and see if the problem still exists?
by Anonymous User
Not applicable
Hi James,
Thank you so much for your prompt reply. I kind of guessed it, but I wasn't sure the problem is our end or another.  I closed the Survey123 for ArcGIS application and clicked Inbox.  However, the problem still exists.  I will try the same sometimes in a day today, but when this updates will be completed?  My colleague would like to inform our client when to try sending/editing the survey data.
Thank you.
JamesTedrick
Hi Makiko,
The update should have been completed last night.  If you are still seeing this issue, can I ask you to do a few debugging steps?  First, does the feature service appear in a normal Map Viewer and can be edited there?  If so, can I ask that you record a log file (look at Troubleshoot—Survey123 for ArcGIS | ArcGIS , though you can just start logging to a text file without needing an AppStudio Console) while attempting to work with the survey and then forward that along?  You can e-mail me directly at jtedrick AT esri.com
