I am creating an inspection form with many begin/end groups. Many of these groups do not need a Label displayed on the form but if the Label field is not populated, I get an XLSForn converted with warnings entry for each blank label field. This is manageable until there are so many the warning window is too large to display the "close" check box. Now I cannot test the form
This did not start happening until I started Beta testing version 3.10.147. As a work-around, I can close the XLSForm and the Survey123 application and restart. The warning message window does not appear until I make a change in the XLSForm and Save to update the Survey Form.
