Calculation in repeats
1280
07-10-2023 07:20 AM
K_Schouten
Hi
Is it possible to perform a calculation within a repeat on previous values ​​in the repeat.
For example, to calculate the distance for a repeat where the new distance is the difference between the two previous repeats (field distance) + the previous distance
Yours sincerely,
Kees Schouten
IsmaelChivite
Esri Notable Contributor
Attaching below an example that may help
K_Schouten
Hi IsmaelChivite,
Thank you for your answer.
Is it also possible to transfer the value of the field distance 2 to the field distance by means of a calculate?
