Calculation in nested repeat not working on decimal fields
816
05-01-2023 09:39 AM
AdriannaBarton
I am encountering an error within a connect form. I have a repeat and a nested repeat table, this issue is occurring on the first repeat record in the nested table. I have fields calculating based on the parent repeat. Most of the calculations are working except for decimal fields, they remain as null on the first repeat. I have tried different calculationMode's but I do not want to use Always; Auto and whenEmpty did not work. Has anyone else encountered this issue?
Katie_Clark
MVP Regular Contributor
Would you be able to post the XLS form? Would help with troubleshooting!
Best,
Katie
If this post helped you, please consider giving a kudos and/or marking as the accepted solution. Thanks!
