Calculation drops 5th question
769
01-02-2025 05:57 AM
LauraBoagey1
I am creating a survey using the web designer
One of the questions is a calculation of the total of 5 other questions (all numbers), but when i click OK after writing the calculation, it drops the 5th question, so there are only 4 being calculated
I'd also duplicated the questions (in a group) and the 2nd and 3rd duplicated questions drops 2 questions, so there are only 3 after clicking OK
But... when i click Preview and test it, it is working as expected... Adding up all 5 questions
How odd
Any ideas?
ZenMasterZeke
One of your screenshots shows 5 questions, another 4. And is the user supposed to perform the calculation themselves with the math operator buttons? I rarely use the web designer, so apologies if this is inaccurate on my part.
LauraBoagey1
ST Classification: UNMARKED
No worries. I raised this as a case with ESRI and they've found it to be a bug in the production environment, so will be working on a fix in the future
The calculation still works as expected, you just can't see the questions in the tool window once you click OK
