BUG: Javascript Slowing Down S123 Field App and Connect
537
5
07-19-2025 08:11 PM
cfransen
I have this javascript which has worked for years, and then as of recent doesn't work most of the time and causes the surveys in the field app to load very slowly.  Has anyone else had issues with javascript in their surveys recently?
// Query the Open Weather API
// https://openweathermap.org/api
// How to get started with the API: https://openweathermap.org/appid
function runWeatherCalcs(lat, lon, time) {
    // Check to make sure we have latitude, longitude and an API key
    if (lat == null || lon == null || time == null) {
        return "";
    // Create the request object
    var xmlhttp = new XMLHttpRequest();
    // Format the URL with the input parameters
    var lat_param = "lat=" + lat;
    var lon_param = "lon=" + lon;
    var time_param = "dt=" + time;
    var key_param = "appid=********************";
    var format_param = "format=json";
    var units_param = "units=imperial";
    var parameters = [lat_param, lon_param, time_param, key_param, format_param, units_param].join("&");
    var url = "https://api.openweathermap.org/data/3.0/onecall/timemachine?" + parameters;
    // Make the request
    xmlhttp.open("GET", url, false); // synchronous
    xmlhttp.send();
    // Check the response. 200 indicates success from the API
    if (xmlhttp.status != 200) {
        return "";
    } else {
        var responseJSON = JSON.parse(xmlhttp.responseText);
        if (responseJSON.error) {
            return "";
        } else {
            if (responseJSON) {
                return JSON.stringify(responseJSON);
            } else {
                return "";
JeffSilberberg
Have you validated that your query is not failing/timing out?  There is no error handling apparent here --
        return "";
 Also, might try executing the query with Postman to validate your expectations.
cfransen
I have tried some more streamlined versions to no avail.  Admittedly this code isn’t air tight, I borrowed it several years ago from a demo, but its worked well up until this latest S123 app update.
VenkataKondepati
Yep, I've seen similar issues lately. Survey123's newer versions don't handle synchronous JavaScript (XMLHttpRequest with false) well anymore — it can cause lag or even break the form, especially on mobile.
Your weather script is making a blocking call, which freezes the app while it waits. I’d suggest moving the API call outside the survey (like using Power Automate or a webhook), or rewriting it with async logic — though async can be tricky in Survey123.
Looks like Esri tightened things up in the latest updates. You're not alone!
Regards,
Venkat
cfransen
Thank you for the feedback, I’ll try to tighten it up a bit and maybe move it to a different service.  This is the second time I’ve been done dirty by S123 this year.
cfransen
Just bumping this, has anyone else had issues with Javascript in S123?
