Browse Image Library, Select Multiple, Confirm Selection
1101
12-20-2022 12:00 PM
EddyClark
Hello- is there a way to control image question behavior?  Field users would like to select multiple photos from the image library before the app returns to the form.
Current behavior is the app will return to the form after one selection from the library.
ZacharySutherby
Hello @EddyClark
Unfortunately, this isn't supported for image questions. We have an internal issue in our backlog to support this in the future but don't have a timeline at this time.
Currently, only the file question type with the multiline appearance allows for multiple selections of files/images in one browse folder selection, and all the files/images will be added to the survey in one go. You can use the body::accept column to limit the types of files that can be uploaded to just image file extensions.
Please see this documentation for more information:
https://doc.arcgis.com/en/survey123/desktop/create-surveys/xlsformmedia.htm#ESRI_SECTION1_A2F2DA5ADD...
Thank you,
Zach
ZacharySutherby
Hello @EddyClark
Thank you,
Zach
