Bold Select Choices in Select Multiple Question
1461
06-28-2024 07:47 AM
ChantelKobilansky
Does anyone know if there is a way to bold some of the choices within a select multiple question? I currently have select multiple choices for plant species found in a plot. Some of the species carry a higher significance thatn others and would like them bold so it is easier to tell which species are more important.
Thanks.
abureaux
MVP Frequent Contributor
Yep. Need to use old HTML.
On the choices tab, use <b>Words</b>
EDIT: here is a better example:
Be aware that this HTML formatting will appear in Feature Reports.
abureaux
ChantelKobilansky
That's perfect, thank you!
