Average value inside repeats
2768
01-15-2019 01:55 AM
PamelaLandy
Hi, Is there any option to calculate the average (the sum of each value entered divided by the number of values entered into a repetition (has no defined value) and can be calculated?
p.e.
"If you enter 02 values, then divided by 02, if you enter 03 values, divided by 03, if you enter N values divided by N "
I think I've only seen it within ideas of improvements.
NicolasRoger
It can be done. Here is how I do it in my survey:
Create 2 field Outside the  reapeat group. One field will use the function Count() on a field within the repeat group and the other will use the Sum() function on that same field.
Then simply divide the results.
PamelaLandy
Thanks, Nicolas
SilverwoodConsulting
Alternatively, create a new row (or field) outside the repeat to calculate the average. The calculation would look something like this:
(sum(${Question_1})) div (count(${Question_1}))
