Automatically Update Coded Values
3356
10
05-17-2017 01:32 PM
TonyDaSilva1
Hi, I was wondering if I am able to write a script to update the Survey123 Form Coded Values periodically because they are time sensitive to changes?
However I noticed that my developer application token is forbidden at the following address
https://www.arcgis.com/sharing/rest/content/users/islgispub/{accountId}/items/{ServiceId}/update
JamesTedrick
Esri Esteemed Contributor
Absolutely - take a look at the 'server-based workflow'.  As part of the token generation process, a the expiration and a refresh token accompanies.  You would have your script store these locally and check the expiration time to now; if less than your criteria, you exchange the refresh token for a new token.  The documentation mentions a 'permanent' token; be advised that capability will be removed in an upcoming ArcGIS Online release.
You may have to start this process manually by using, manually constructed urls, a local web server that won't attempt to process the codes or tokens as your redirect_URI  & Postman or curl to complete the authorization code > token and initial (short life) token > long life token exchanges.
