Autocomplete search not pulling options for downdown list
6770
10
10-20-2023 03:35 PM
RutledgeNicholas
I am trying to pull a list of Case IDs into a dropdown menu using Survey123 Connect.
I've inserted the following info in the appearance column of a "select_one list_caseID" row:
autocomplete search('list_case_id?url=https://services8.arcgis.com/euhkr1dAJeQBIjV0/arcgis/rest/services/service_fb0410d92ff74e75981d175d7...')
The dropdown field is blank and even when I type in the field, no results populate.
Can someone help me with this?
D_AnneHammond
Yes I certainly will, your answer makes perfect sense, thank you!
