Auto populate list from related table through URL?
677
05-22-2020 05:01 AM
by Anonymous User
Not applicable
Is it possible to auto populate a drop down list of choices from a url?  I have a form for funding grants and then a form for funding projects. The user clicks on a polygon and fills out a form about funding grants (there can be multiple). I want them to then be able to open the survey for projects and be able to select which funding grant record to relate it back to .
JamesTedrick
Esri Esteemed Contributor
Hi Katie,
At this time, it is not possible to populate a list of choices from a dynamic source such as a URL.
DougBrowning
MVP Esteemed Contributor
If you are launching the form from polygons in Collector or a web map you could pass the grant number over via a URL.  Not sure about multiple unless they are all in the same field or you have grant 1, 2, 3 or something.  You can just populate a field though and not a list.
