Auto advance to next question
1098
02-26-2019 01:26 PM
AllisonHollier1
I keep looking for the "quick" appearance option for select one questions, but apparently that's not an option in Survey 123 connect?  Any other suggestions as to how to get that to work?
Also trying to figure out if there's a way to populate a punch list (Excel spreadsheet?) if an item needs additional work?
BrettStokes
Hi Allison,
Are you referring to the 'quickcompact' appearance type that is part of the XLSFrom spec? If so, it is not supported in Survey123. Can you please explain what you mean by a 'punch list', I'm not really sure what you're trying to figure out.
Brett
