Allow feature and summary reporting for Enterprise/Portal on a Azure environment
1445
02-17-2021 06:14 PM
ECarson
Hi All,
Has anyone managed to use the feature/summary reporting functionality though their Enterprise/Portal environment?
Ours is hosted on an Azure environment.
When trying to to create a sample template or upload a template we get the following abbreviate error.
request to https://"server & token"... failed, reason: connect ETIMEDOUT XX.XX.XX.XX:443
Could anyone provide any insights or steps required to allow the use of the reporting functionality via Enterprise/Portal?
Regards,
Elliott
ZacharySutherby
Hello @ECarson
Please see the ArcGIS Enterprise support section of this Esri Community blog for what's required to work with reports in ArcGIS Enterprise.
The main requirements are your ArcGIS Enterprise organization needs to be accessible over the internet so that the Survey123 report API can communicate with the organization, and the organization cannot be configured with Integrated Windows Authentication (IWA).
Thank you,
Zach
Thank you,
Zach
