Admiralty API - Request Headers syntax
1363
10-23-2022 06:45 AM
ChrisMaclaurin
Hi 🙂 I am tying to call back tide station data to populate a survey form using Admiralty API. I used to use csv files for the approprate stations / day / tide data but I have to update these every year manually. Yawn!
I have not come accross request headers using JavaScript before and I am struggling with the syntax. what I have so far is...
function runTideCalcs(){
var xmlhttp = new XMLHttpRequest();
var url = `https://admiraltyapi.azure-api.net/uktidalapi/api/V1/Stations/0065/TidalEvents?duration=1`;
xmlhttp.open("GET",url,false);
xmlhttp.send();
if (xmlhttp.status!=200){
return null;
} else {
var responseJSON=JSON.parse(xmlhttp.responseText)
if (responseJSON.error){
return responseJSON.error;
} else {
if (responseJSON){
return JSON.stringify(responseJSON);
else {
return "";
....But I am not sure what syntax or where to incorporate the
setRequestHeader("Ocp-Apim-Subscription-Key","{subscription key}");
Naturally I have an Admiralty account and Sub. key. Any pointers would be very welcome.
Thanks
Chris
2 Solutions
ZacharySutherby
Hello @ChrisMaclaurin
I would suggest using an API debugging software like Postman for example, Postman has a nice GUI that help set up the API call to get it in a state where it is working. When it's up and running in Postman there is a nice code snippet functionality that will format the request in a JavaScript XHR format that you can copy over to your JavaScript function and modify as needed.
Thank you,
Zach
ChrisMaclaurin
Hi @ZacharySutherby,
Thanks for the awsome tip! I was so almost there, but using Postman was an excellent suggestion - a few other tweeks and I was there. Postman will certainly come in useful again in future for other projects too, so 1000 thank yous for the signpost. v. much appreciated.
Chris
ZacharySutherby
Thank you,
Zach
ChrisMaclaurin
Chris
