Adding multiple points on map
1111
02-18-2023 02:47 AM
NinoChkhartishvili
Hello all!
The survey respondent tries to add several points on the map, but after adding one point, the previous one disappears. However, the specificity of the question requires inserting multiple shapes.
I wonder if it is possible in ArcGIS Survey 123 to add multiple points/other shapes on a map while answering the question?
Thanks a lot for your responses!
Best regards,
Nino
MobiusSnake
MVP Regular Contributor
Your best bet is probably to put your geopoint question into a repeat.  You can configure a repeat to require a specific number of points, or a minimum number of points, or a maximum number of points.
