add table to an existing feature
1792
10-03-2020 02:27 PM
OussamaMerhi
I have a form already published and contains data. The operation manager decided to add a repeating table to the published on which contains a geopoint. When you try to add repeating to the exisiting form all previous data will be deleted. is there anyway to create the new geopoint table and then make relationship  with the main form. so in that way when you go back to add repeating table to the form you will not loose the old data.
Tags (1)
SMauri
Hi Oussama Merhi‌,
just make this step:
  • download data in a FGDB format
  • insert your table and create a relationship based on GlobalID of your feature class
  • overwrite your feature layer hosted with this new dataset
Cheers
Stefano
OussamaMerhi
Hi Stefano,
I appreciate if you can send to me the steps. which is better ArcGispro or Arcmap?
Thank you for your coordination.
Best,
Oussama
SMauri
ArcGIS Pro, because you can Overwrite a web feature layer—ArcGIS Pro | Documentation without any problem.
Regards
Stefano
