I have a form already published and contains data. The operation manager decided to add a repeating table to the published on which contains a geopoint. When you try to add repeating to the exisiting form all previous data will be deleted. is there anyway to create the new geopoint table and then make relationship with the main form. so in that way when you go back to add repeating table to the form you will not loose the old data.
Hi Oussama Merhi,
just make this step:
Cheers
Stefano
Hi Stefano,
I appreciate if you can send to me the steps. which is better ArcGispro or Arcmap?
Thank you for your coordination.
Best,
Oussama
ArcGIS Pro, because you can Overwrite a web feature layer—ArcGIS Pro | Documentation without any problem.
Regards
Stefano
