Add a date constraint into Connect123 to only allow submissions 7 working days from now
468
09-05-2024 04:23 AM
AndrewReynoldsDevon
I'm working on a form in connect 123 which is published to arc enterprise 10.8.1 where the customer wants the form to not allow submissions before 7 working days from now. So for example 6 working days from now would generate an error but 7 working days from now would be ok.
It needs to be clever enough to recognise English bank holidays & weekends.
The constraint message would say something like 'sorry you're trying to submit the form too early'
I've used this code '.> date(decimal-date-time(now()) + 10)' in the constraint column which is working for me but it recognise the difference between weekends, bank holidays & working days so this is what I'd like to aim towards if possible
DuncanC
Are you allowed javascript?  Or is the form public facing (javascript in Survey123 is disabled)?
Without javascript I don't think it's possible.  With javascript it's doable, but my solution is still uglier than I'd like.  I don't know of a good way to load the list of bank holidays and would likely hard code it into the script and throw up a little in my mouth while doing so.  But how do I pass it an array?  Or have it access a CSV file?  I don't know if you can.  Once you have a list of dates in javascript it should be pretty trivial to calculate the date.
