Resize Map in Survey123 Web Form
3020
01-17-2024 02:33 PM
Status: Open
KellyTaylor
I would love to be able to resize the map (or maybe even the entire survey area) for geo questions in the web app for Survey123. Another option would be to allow the user to make the map full screen, like a popup. Right now, my geoshape question is pretty inaccessible to my end users, many of whom are older and/or have bad eyes and/or aren't the most tech savvy.
Look how teeny tiny that map is (screenshot below)! It's barely accessible to me, and I'm a map & tech professional.
Tags (1)
5 Comments
Jim-Moore
Hi @KellyTaylor
In the Survey123 web app, you can open the map in a full screen pop-up by clicking the Large map button on the map:
The idea to be able to display the map in the form at a different size could be a good one - something similar is available in Survey123 Connect, where you can set the question height for geo* questions in the field app.
Best, Jim
KellyTaylor
Aw man, Idk how I missed that! Well, thanks.
konsta_kuorikoski
There should be option to scale map bigger similar to how Google Maps are scalable through API embed. While we can make whole form wider through URL parameters, map will stay with same height. It should scale with the form, at least in a way where the aspect ration remains the same.
MapsAreFun
I'm interested in how you can increase the map height also. I have made my map wider using ?width=1200 but I have not found a way to increase the height.
As per Solved: Re: Survey123 Map View Size - Esri Community, I have tried adding both defaultHeight=50% and height=50% to the body::esri:style field but it hasn't changed the height of my map. I would like it to work in the browser. Any ideas would be appreciated.
BrandonPrice1
I am also interested in increasing the map height in web. The provided method increased the height in Survey123 Connect, but it didn't hold after publishing it to web.
