Make data results form view accessible directly
602
09-25-2025 01:24 PM
Status: Open
KevinMcMaster2
The form view in data results is exactly what is needed in the pop-up of a survey point when sharing the results of a survey (see the circled area in the attached photo). It skips empty fields, it formats all the concatenated, comma-separated data into perfect bullet points using the english text and not the data value, it has pictures laid out as entered into the survey, and... unfortunately, it seems completely unaccessible anywhere other than in the data results view. My idea is: can the form view be made into a separate, URL parameter-accessible endpoint? It could then be embedded into dashboards, web-apps, etc.
Thank you!
Kevin
