hidden fields
1836
6
08-10-2020 07:16 AM
Status: Open
ReneAubut
I would like hidden fields in survey123 Connect to be by default invisible in Survey123 website
6 Comments
JamesTedrick
Questions with the 'hidden' type already do not show on the web app.  If you are referring to the 'hidden' appearance or the body::esri:visible column, these are beta features described in the Early Adopter Community - part of the plan for their release is support in the web app.
ReneAubut
Am referring to https://survey123.arcgis.com/surveys  where Survey123 Connect HIDDEN type questions are visible by default. Would be nice if https://survey123.arcgis.com/surveys  would follow the visualization settings done in ArcGIS Online
JamesTedrick
Hi Rene,
Just to confirm, are you asking about having the fields nonviable in the 'Data' and 'Analyze' tabs?
ReneAubut
James, sorry I forgot to mention, I am looking at the data tab. Our user will be working in the Data tab, selecting one record and printing it. So all my HIDDEN type questions should not appear on both the Data tab and the printed records. Thanks
JamesTedrick
Thanks for the clarification.  Given that, I'll reset the status of this issue to 'Reviewed'.  To note, the report capability allows you to specify exactly which fields are displayed in a printable record.
ReneAubut
yes for reports, which we wont be using (credits...) Print will be enough for our needs
