Change survey submission url from web builder
1536
07-04-2021 02:09 PM
Status: Open
Labels (2)
FrancisCorbett
After publishing a survey, it is sometimes necessary to change the submission URL to point to a view of the original published feature service (for example to protect sensitive data). It would be helpful to be able to do this from the web builder when the web builder is used to publish the survey, rather than downloading and finishing in Survey123 Connect.
2 Comments
Ruth_JiatengXu
Hi @FrancisCorbett ,
Thanks for sharing here! The web builder does not support changing submission URL, but the web builder already creates views of the original published feature service to protect your data.
When you publish a survey from web builder, the web builder automatically creates 2 views, surveyName_fieldworker view is used to collect the result, and the surveyName_stakeholder view is used to shared to result. You can see this blog post for more information: Securing data in public surveys (Survey123 web designer) .
If the current fieldworker and stakeholder views cannot satisfy the needs, please share more details relates to your use case.
Ruth
FrancisCorbett
Thanks @Ruth_JiatengXu for your help. That makes sense, Francis
