Add to Analyze Survey Tool: When character limit within name column over 31
213
07-10-2024 02:37 PM
Status: Open
Labels (3)
JenFrazer_USFS_NR-GISS-IRIN
Premise: You can tier other platforms off of Survey123.  The design rules of these platforms are not always reflected in the design constraints or rules of Survey123.
Idea: Please add to the Analyze Survey Tool in Survey123 Connect the filter: Character limit of a name field name is over 31 characters.
Why: When creating view layers (for view only use) off of survey123 feature services, these fields are throwing fatal flaw errors in Field Maps Designer.
1 Comment
abureaux
Connect should already warn you of that character limit:
And when you ignore that message:
Or do you mean exclusively on the "choices" tab? That should have a warning added.
