Understanding Notes in Survey123
26290
15
11-14-2017 02:54 AM
IsmaelChivite
Esri Notable Contributor
10 15 26.3K
Surveys are for the most part about questions, but often you need to provide some context before users can actually give you a good answer. And that is where notes come into play.
Notes allow you to insert text and images in between questions in your Survey123 smart form
Here are the main three reasons why you may want to use notes in your form:
  1. Information: Notes are useful when you want to provide users with information that will help them capture data more appropriately. In an invasive species survey, for example, a note could warn the user that the inventory should be performed in a radius of 100 meters from a given sampling point. In a population census enumeration survey, notes can also include certain tips for the enumerator to introduce questions to respondents.
  2. Warnings: Notes can be used to warn users about inconsistencies in the data captured, before it is  submitted. For example, if we do not want people to capture the location of an observation while on the move, we can make a warning note visible whenever we detect that the geopoint object has a speed larger than 0 meters per second. We could also use a warning note if we detect some  logical inconsistencies in the captured data.  Of course, we could use constraints in Survey123 to prevent all this bad  data to be submitted, but notes provide a nice way to bring the user's attention into these  problems early.
  3. Look&Feel: Finally, notes are a great way to display banners and logos into your form to make them look exactly as you want.
The Basics
The use of notes is supported in both the Survey123’s web designer as well as Survey123 Connect. The easiest way to create a note is to use web designer, where you can easily format your text using custom font sizes, colors, bullets for your paragraphs and even embedded images and links. You can also control the alignment of your text in the notes: centered, right aligned and left aligned.
Here is how you can add notes to your survey in Web Designer:
(view in My Videos)
Notes in XLSForms
In XLSForms, notes are modeled as a note type of question.  The most important rule when using notes is that they do not require any value in the name column of your XLSForm. That is right: unlike other types of questions in XLSForms, the name column is not mandatory. In fact, it is typically better that you leave it empty.
The reason for this is simple: When you publish a survey with Survey123 Connect, the values in the name column of the survey worksheet define the attribute columns in the feature layer where we will persist your data.  Since notes do not expect any user input, there is no need to  give them a name.
Other than the above, notes behave like most other XLSform questions:
  • HTML formatting is supported in notes. You can use  HTML formatting for way more than cosmetic reasons. You can for  example add links. In the next example, I added a link that will trigger a phone call to the Water Department.
typenamelabel
note <center><a href="tel:9091234567">Call Water Department</a></center></p>
  • Media: You can associate media to a note question. Use the media:audio and media::image columns for this. In the next example, a note is used to allow the user to play an audio file from the survey.  Images and audio files referenced must be stored in the media folder of your survey.
typenamelabelmedia::audio
note Play this audio before counting <i>Gubernatrix cristata</i> callsgcristata.mp3
  • Relevant: Relevant expressions can be used to make notes appear and hide. In the next example, A warning is shown to the user if the location is fixed while on the move. When adding warnings, I like to use HTML formatting to display the notes in red or other color.
typenamelabelrelevantcalculation
geopointlocationLocation
calculatespeedSpeed pulldata("@geopoint", ${location}, "speed")
note Do not move while fixing location!0.2 < ${speed}
  • Calculations: You can use calculations to display text in the main body of a note. In the following example, a note is used to indicate the number of choices selected in a select multiple question.
typenamelabelcalculation
select_multiple violationsviolationsCode Violations
note Violations observedcount-selected(${violations})
When calculating a note, you may want to have  your text all be shown in one single line, rather  than split in two like above. If that is the case, you can do something like the following:
note </b>concat("Violations: ", count-selected(${violations}))
The only reason I use </b> in the label is because the label column is mandatory for a note. <b> will not render any text, so the main body of the note will read a a single  line of text, which is what  I want.
Tags (3)
15 Comments
LucianoCampagnolo1
Hi Ismael Chivite‌!
How would you do a calculation Note that pulls the responses from a repeated group?
Not, or not limited to, sum() count().... More like a summary/digest of some of the fields in all responses in a repeated set of questions.
Cheers,
Luc
NickDierks
Is there any possibility of allowing notes to have name values without Connect trying to add fields for each one? I've found it very useful on several surveys to name them for easy identification when writing/editing. It's particularly useful when there are several conditional notes that include a lot of html formatting, making them hard to quickly read and identify at a glance in the spreadsheet. Should I just start marking every named note "null" in the bind::esri:fieldType column, or give up trying to include a quick identifier in the name field altogether?
JamesTedrick
Esri Esteemed Contributor
Hi Nick,
Yes, if you want to provide a quick identifier for the note, set the fieldType to null to prevent field creation.
LucianoCampagnolo1
Hi James‌!,
Do you have any idea on how to deal with my previous question?
I need to insert a Note with the individual responses (to some fields) from a repeated set of questions...
Best regards,
Luc
JamesTedrick
Hi Luciano,
What are you looking for in terms of a summary digest?  In general, you are limited to what you can generate with aggregation functions (sum, count, min, max), so it sounds like it might be a bit beyond the current calculation capabilities.
LucianoCampagnolo1
Thanks James!
Yes, that is what I need.... Unfortunately, I think I've hit a wall here.
Thanks again,
Luc
by Anonymous User
Not applicable
Ismael,
Do you know of any examples of municipalities in North America using Survey123 for census enumeration. Can you point us to a case study or example configuration?
thank you.
KingTides
Ismael,
Is it possible to use HTML code to create an email link so people using the survey can click the link and it opens their email application with an auto populated subject and to field.This is so feedback about the survey can easily be submitted.
Thanks ahead of time!
JamesTedrick
It's quite possible to make a link - look at mailto - Wikipedia for how to construct the link properly.
AndrewHargreaves2
Hi James Tedrick
I looked at the Wiki page, but am running into an issue using the below in a calculate for a note:
concat("<a href='mailto:Andrew.Hargreaves@xxxxxxx.com", "?Subject=", ${AGO_USER}, "%20needs%20help%20",  "%20'%20", ">CLICK HERE TO EMAIL ANDREW DIRECTLY</a>")
For your info ${AGO_USER} is a note calculated using 'property('username')'. I keep getting told:
Any advice is gratefully received.
Thanks
ChrisRoberts2
Ismael
Your note example above has bullet points to assess fire severity.  How did you get bullet point in the note...I am having trouble emulating that.
Cheers
Chris
JamesTedrick
Hi Chris,
Ismael used the HTML unordered list (<ul>) to format the list.
R_Millman
I have a note field that is pulling data from a csv when previous entered text matches a record in the csv.  I'd like to then put a relevant statement on a following question based on whether a match is made - is it possible to use a statement that determines whether the note is more than 0 characters long?
JerrySneary
Hi @R_Millman ,
I'm not sure what you are trying to accomplish exactly but I use this string-length code in my relevant column. Hope this helps.
string-length(${your_field_name_here})>0
AmandaBeck
Hi @IsmaelChivite
I am creating a survey in Survey123 connect and am hoping to use a Warning. I have a geopoint question that asks the user to place a point where their septic system is located. What I would like to have happen is that when the user selects the location, a warning message appears stating whether their septic system is or is not eligible.
The basemap for the geopoint question contains a parcel layer in which data is pulled for other questions throughout the survey.
Is there a way that I can do this? I have tried to use a constraint, which was successful, however, I would like the users to still be able to submit the survey even if their septic system is outside the eligible list.
Thanks in advance for any guidance you can offer!
