Problem with Intersections in two Locators built on the same street centerline
2915
12-07-2011 06:22 AM
CathyStanley
I am in charge of the GIS data for our 9-1-1 Center.  We have a very large street centerline and I have taken on the task of cleaning up the data and making it more functional for our Center and Emergency Responders.  One of the additions I have made to our data is the use of Exit Ramps for our Interstates.  I've added in block ranges for the Interstate to flow along with our Mile Markers.  I have also added small ranges for the Exits.  Our current centerline contains a single street name field and parsed fields.  The Mapping used in our Center's software relies on the parsed fields for geoverification. When I use the Locator built using the single street name field, my intersections with Interstate / Exit works fine.  However, when I use the Locator built using the parsed street fields, the same intersections will not verify.  I have already run a TRIM command with all of the fields to remove any leading / trailing spaces.  Everything looks exactly the same.  Can anyone explain why the Locator using the parsed fields will not verify these intersections?
Tags (1)
PatrickStevens
Hello! I see that you haven't had a reply to your query yet. You might have better luck reposting this on the geocoding forum.
