hot spot map
4001
06-14-2012 01:52 PM
ColleenAskren
I'm doing a hot spot density map using the kernal option.  It turns out well but it seems to make a big square in the middle that cuts off some of the hot spots on the edge of the square.  So it looks a little odd.   Is there some setting that I'm missing?
Tags (1)
PaulDoherty1
I would like to help you figure out what the problem is. Certainly a big square in the middle of your map does not sound normal or helpful! Perhaps you can send me an email at [email protected] and we can discuss a data exchange so I can take a look. Then perhaps we can post a solution for others to read.
Kernel density can be a very helpful visualization tool for quickly making a more meaningful picture of your â??dots on the mapâ?�. However, to really analyze the data you may want to take a look at some other tools already available at your disposal, such as Hot Spot Analysis. For supporting decision making inthe Public Safety Community this is a best practice.
For more about the spatial statistics toolbox please see our Spatial Statistics Resources page http://esriurl.com/spatialstats.
I look forward to hearing from you.
- Paul
ColleenAskren
Thanks for your help, Paul!   It turned out to be an environment setting issue.  I simply changed the setting to include the extent of the biggest layer I was using.   Worked great.:)
PaulDoherty1
I am glad we could help! For more on environment settings and output extent please see the Help topic http://resources.arcgis.com/en/help/main/10.1/index.html#/Output_Extent/001w00000009000000/.
Thank you for posting/reading.
- Paul
