Storymaps Webmap Modifications
1024
01-10-2024 04:07 PM
DavidForbuss1
Is it possible to customize the underlying webmap that has the points in my Storymap?  I'd like to show labels on the individual points, but I don't see that option anywhere, and I can't find the underlying webmap to modify it directly.
OwenGeo
Esri Notable Contributor
@DavidForbuss1 -- Looks like this is a map tour, so there is no underlying web map. However, you can change the basemap for your tour in the tour's Map options (the gear button the the top right corner of the tour map).
You can pick from one of the provided basemaps or browse to your own web map and use it's basemap. For more information, see the BYOB(asemap) section of this article: Boost your map tour experience with countdowns, 3D globes, and more (esri.com)
However, there isn't a way to enable labels on map tour points at this time. If you need labels to show all the time, I would recommend using a web map where you will have control over that aspect of the map appearance.
Owen Evans
