Slow loading map tours on StoryMap
1574
11-18-2024 01:13 PM
Labels (3)
SarahPearce
Hello! I recently created a StoryMap that involves two map tours. Both of these seem to be significantly slow in loading and laggy when they do load. I’ve tried everything I can think of: deleting all unnecessary layers, switching out the base map, trying the StoryMap from different browsers and computers… I can’t seem to figure it out.
Here’s a link to the StoryMap: https://arcg.is/15Te9n0
Thank you so much for the help!
AbbyE_Esri
Hi @SarahPearce , What a great story! On my end, I'm not seeing a loading/lagging issue. Would you be able to share a screen recording of the loading you're seeing? I am wondering if it may be a networking issue. Have you tested outside of your current Wi-Fi/network?
--Abby
SarahPearce
Hi @AbbyE_Esri !
Thank you so much for the quick response, and I'm so glad you enjoyed the story. 🙂 I have tried it outside of my network; there's a few authors/collaborators on the map, and they've also reported having some troubles with slow loading/lagging.
Here's a screen recording of what it looks like on my end!
(view in My Videos)
Again, thank you so much for your help. 🙂
Sarah
ShaneONeill_144
I just tested on my end and performance was fine - what browsers are in use? Are the performance issues all in the same browser?
If you duplicate the storymap, are you seeing the same issues in that?
OwenGeo
Esri Notable Contributor
@SarahPearce - I wonder if the slight lagginess you are seeing could be from the polygon layer. If that is a very detailed layer, you might want to try generalizing it to remove some of the detail to see if that helps.
Owen Evans
