Renaming Features not saving
1247
08-30-2022 07:03 AM
JordanHedlund
When I rename a feature and save it is not reflected in the legend for the associate storymaps.
For instance, when I add a feature that says "Stream_Dissolved" and I rename to "Stream" and save, I will place the map again and publish but the legend will still say Stream_Dissolved.
OwenGeo
Esri Notable Contributor
Hi @JordanHedlund -- Just wanted to clarify, but from what you are describing I believe you are editing the name of the layer in a web map (not a feature in a layer), is that correct?
If so, this is currently expected behavior but we understand this is not ideal in this situation. We are looking at adding a way to refresh the legend information if changes have been made to a web map in a future release. At the moment, you'll need to re-add the map to the story to see any legend changes reflected in your story.
Owen Evans
OwenGeo
Owen Evans
