remove previously added text separators - sidecar layout
2607
06-21-2023 11:01 AM
MerlinSmith
I inserted separators into my text in the Sidecar layout. I deleted the text but I can't delete the separators.
Many thanks,
MerlinI can't delete the separators.I can't delete the separators.
OwenGeo
Esri Notable Contributor
Thanks for figuring this out @GISWisDom! We'll take a look at this bug and fix the color of those icons in an upcoming release.
@MerlinSmith - You should be able to hover over the separator and then move your mouse to the right until you see the cursor change to a hand/pointer. Just click the mouse when that happens and the separator should be removed. Or it might be easier to just temporarily swap to a different theme so the icons are visible.
Owen Evans
EllieHakariAK
Hi @MerlinSmith! I created a sidecar and added a bunch of separators to test this issue. On my end, when I hover over a separator it shows a trashcan on the righthand side. Clicking this deletes the separator. Are you able to see this on your end?
MerlinSmith
Thank you for your help. No, I do not see a trashcan when I over the
divider dots.
OwenGeo
@MerlinSmith -- I'm sorry you are having an issue removing separators from your story. Could you please share a screenshot of the entire screen with your mouse hovering over the separator dots? Perhaps that will provide us with some more information to determine what might be going on.
Owen Evans
GISWisDom
I am also having this same issue with a custom separator in a custom theme.
Discovered that the custom colours I am using do not allow any contrast between the trashcan and my background.
The trashcan is there, but it just can't be seen.
OwenGeo
Owen Evans
