Reconnect maps in copied story maps?
553
08-25-2025 05:39 PM
JoHathway
I have copied my content (maps, feature layers, story maps etc) from my current account to a new account. The maps in the copied StoryMaps still reference the maps on my original account - so when they are unpublished these will not appear in the new StoryMaps. There is (identical) copied maps in my new account - can I connect to these instead of the ones in the previous account? Without having to recreate the sidecars / map tours etc in the copied StoryMaps?
OwenGeo
Esri Notable Contributor
@JoHathway -- There isn't a way to swap in new maps or layers from the builders, but you can use the storymaps module of the Python API or a tool like ArcGIS Assistant to edit the story data to swap in the new itemIDs for the old ones.
There is a bit of information here to help guide you about where to make these edits using Assistant, but please be aware that this is not a supported workflow, and any changes you make are at your own risk. I would recommend making sure you have copies of your content in case the editing breaks the story and test things out on copies.
Owen Evans
OwenGeo
Owen Evans
JoHathway
Thanks Owen, that has got me started again - I worked out how to replace the map IDs but then the layers didn't match/connect (and the referenced layer IDs didn't match anhy of the layer IDs I have in the account), I think I need to relink all the layers in the web maps before editing the JSON file. Appreciate your advice.
OwenGeo
@JoHathway - Yes, any IDs that point to old items -- whether they are in the StoryMap, web maps, apps, etc. -- will need to be updated.
Owen Evans
