Publishing failure
326
6
04-13-2023 12:20 PM
geomatique_devvs
I recently updated a story that was working fine by changing a map. When I try to publish the story with the new map, it says "Some of your story could not be checked for issues" and "There was a problem publishing your story" . Now the story is published but I see gray screens where I should see my new maps. The sharing is set to public. Out of ideas.
geomatique_devvs
Nvm, story is now deleted. No matter the map I added, it would never work (be it web map or express). I think supressing the first map while it was still used in the story somehow corrupted the story. I redid it from scratch.
geomatique_devvs
Edit: Sharing is set to public on both story & map
AbbyE_Esri
Hi @geomatique_devvs,
I'm sorry you're seeing issues with this story. Could you send over a link to this story so we can try and see what you're seeing?
--Abby
geomatique_devvs
Sure, here goes!
https://storymaps.arcgis.com/stories/f664dc1e367e44ceabcac9517eb4c273
I have a couple slides using the same map (which does not appear) near the end of the story.
Thanks.
geomatique_devvs
AbbyE_Esri
@geomatique_devvs I'm sorry you had to recreate the story. I was able to take a look before it was gone, and was also seeing the blank maps at the bottom. It is interesting that it was both web maps and express maps that weren't functioning. I wasn't seeing any errors within the web traffic of the page, either.
In your new story, are you able to see the same web maps successfully, or did you need to recreate those from scratch as well?
--Abby
geomatique_devvs
The maps that weren't shown initially in the first story are showing up without any problem in the second story! Thanks for looking into it.
