Hello Mia -- Thank you for reporting this issue.
This appears to be a problem only when the story is viewed in Safari as part of a collection (as it is in the link you shared above). There is no issue if you access the story directly using this link: (Farm) Animal Planet.
The maps in that sidecar section are static images, so this is not a problem with map rendering. There appears to be a difference in the way Safari loads and displays images in embedded stories.
We'll look into this more and plan to address it in our next release.
Owen
Owen Evans
