ArcGIS StoryMaps Map Tour error: “The data source for this tour no longer exists or you do not have the permission to use it”
891
02-03-2026 01:09 AM
TerezieVaňková
I’m building a Map Tour and I keep getting this error message:
The data source for this tour no longer exists or you do not have the permission to use it.
I've repeatedly created a hosted feature layer shared with the entire public and extensively used ChatGPT for help troubleshooting.
The field names include Name, Description, and Image.
In StoryMap it only works for one hosted feature layer, the other ones from the same map aren´t working.
OwenGeo
Esri Notable Contributor
@TerezieVaňková -- I'm sorry you are having an issue creating a map tour. Could you share more information about the feature services and story that aren't working? Or, even better, are you able to share them with everyone and provide links to them here so we can investigate?
Owen Evans
TerezieVaňková
Hello, thank you for your reply.
I am sending link to the Storymaps https://arcg.is/5P8WD0
Here is the link of the map itself https://arcg.is/4aeyP
In the picture is one hosted feature layer called "scertynejsouzertymista", it is the only one that works in a map tour. In the second picture is a photo of an error for other hosted feature layers from the same map.
It says
but the layers exist (I can use them in the Storymap but not in the map tour) and they are all visible for everyone.
I am sorry, but the project is in the czech language.
Thank you for your help, I really appreciate it.
Have a nice day.
TerezieVaňková
@OwenGeo Hi, I'm sorry for pinging, I would appreciate your answer asap, because I have this project for school purposes. Thank you!
OwenGeo
@TerezieVaňková - We took a look, but it's not immediately apparent what's going on and we can't reproduce this issue with other stories. Please contact Esri Technical Support and they can help you troubleshoot further.
Owen Evans
