Story Map with Polylines or Polygones
1731
05-12-2014 06:43 AM
AntoineRICHARD
Hello, is it possible to build a story map not only with a layer of points, but also with polylines and polygones layers ?
This will be better for the extents, scales and symbologies.
Best regards,thanks a lot.
Antoine Richard
4 Comments
EmilyLee
This would be a very good idea. Thank you!
OwenGeo
While you currently need to build a Map Tour with a point layer, you can add layers to your web map (which can be polygon or line layers).
See this blog post for details and some examples of this.
http://blogs.esri.com/esri/arcgis/2015/07/28/add-layers-to-your-map-tour/
NaomiBegg2
It's all very well showing polygon layer on the map of the story map ... but what we really need is to be able to have a record in the story map relating to each of the polygons and have it zoom and highlight the one that it is currently looking at.
OwenGeo
See also Guided tour four Lines/Routes (closed)
