Expose Node IDs in StoryMap Editor
425
04-01-2026 11:27 AM
RobertMatthewmanCTCLUSI
When editing a StoryMap, I would like to be able to see the node-id of an element I'm working with. That way I could also access the node's properties using the API Python library if I wanted to edit it programmatically. Currently, if I want to look at a StoryMap's visual output and then correlate it to a node ID, I have to open ArcGIS Assistant, open the source .json, Ctrl-F search for the closest identifiable text string and scan for the nodes in the json.
1 Comment
OwenGeo
