Color options for Collections header navigation
1806
01-03-2025 09:22 AM
Status: Implemented
Labels (2)
AaronKoelker
Currently, we can adjust the appearance of a StoryMap Collection's landing page via themes (which is great!). However, the themes do not apply to the header navigation buttons for both the tabbed and bulleted layouts. The backing color instead retains the default StoryMaps teal.
It would be great if the StoryMap Collection pulled the color for these from the Button settings within the applied theme. Or if there are concerns with introducing accessibility issues here, at least giving users the option to change it to some neutral color combination like grey and black.
This would be beneficial for organizations with strict branding policies, as well as to simply help the Collection appear more cohesive.
5 Comments
AaronKoelker
Update: Perhaps this is just user error? I came across an example that appears to have theme colors applied to the header navigation. I went into my own theme settings and found there is a check box to "Use theme colors" for the header, and the tooltip says "Uses your theme’s background color, body text color, and fonts", however it's still unclear to me how this is determining the colors. Below is an example where the theme background is deep green and the body text is white, and when you hover the mouse over a tab it changes to a lighter green. Unclear where the lighter green comes from--if it's in the theme settings or if the StoryMap automatically dynamically takes a different value of the background hue.
Here is my own example where I've applied a theme with a white background and black text, and my accent color is orange. But the hover highlight is grey and the selected story is black.
If this isn't just user error, then maybe the idea can be updated simply to clarify or give more control with how the theme is applied to the Collection navigation header.
OwenGeo
@AaronKoelker - We are working on some improvements and new options for theming the header, including the collection navigation bar, that should be released before the end of this quarter (2025 Q1).
The collection you referred to above is likely using a theme with the "Use theme colors" header option and has a greenish-black (like #0b2808) as the background color, which causes the active color to be green.
OwenGeo
AaronKoelker
@OwenGeo Ah okay, I understand it now, thank you. Looking forward to the update, then.
OwenGeo
Theme builder now enables you to fully customize the header colors. This includes improved support for theme colors for the collection navigation bar.
For more information, see What's new in ArcGIS StoryMaps (February 2025)
