z-factor
4752
08-06-2013 06:45 AM
DanielRockefeller1
I'm relatively new to GIS and I'm attempting to calculate the slope from a DEM raster of the Adirondack Park.
<Spatial_Reference>NAD_1983_UTM_Zone_18N
<Linear_Unit>Meter (1.000000)</Linear_Unit>
<Angular_Unit>Degree (0.017453292519943295)
I'm having trouble understanding how to determine if I need to change the z-factor from the default "1" and then which z-factor to use if one is needed.
Can anyone lend a hand?
Luke_Pinner
MVP Regular Contributor
Your linear units (XY) are metres. You do not need to change the Z factor as your elevation values should also be in metres. If for some reason your elevation values are in feet, you would use a z-factor of 0.3048 to convert your elevation from feet to meters (1 foot = 0.3048 meters).
Ignore below (It's only relevant if your linear units are in degrees).
See this thread: Z factor in slope tool and these articles: Setting the Z Factor parameter correctly and Determining a Z-factor for scaling linear elevation units to match geographic coordinate values.
NoahHuntington
If my  x y units are feet do I use the inverse for a z factor of 3.2808?
Luke_Pinner
