When saving shapefile as raster file, ArcMap 10.3 crashed. Any idea how to fix this? Snapshot of the issue below:
1515
11-10-2016 12:42 AM
JijiaNiang
DanPatterson_Retired
pretty well anything, like trying to convert a floating point values to a raster, way too many values to convert, a bad file path...
The important information isn't that it crashed, but
  • what was the extent and cell size used?
  • what was the path, name and type of the raster you were trying to create?
  • does it crash on all files or just this one?
  • did you try a portion of the file to rule out file size issues?
  • did you try it on another machine to rule out machine issues?
  • did you have background geoprocessing turned on?
  • anything else not listed above
AdrianWelsh
MVP Honored Contributor
Jijia,
Can you install ArcGIS 10.3.1? I wonder if that kind of issue was fixed in 10.3.1? (Or maybe even go to 10.4.1)?
